با این کد میتونی او ن قسمت رو جدا کنی
کافیه به عنوان یک تابع بنویسیش و صداش بزنی
کد:void setup() { // put your setup code here, to run once: Serial.begin(9600); String code = "IPD,0,10:arduino.ir+" ; int firstClosingBracket = code.indexOf(':'); Serial.println("The First index of ; in the string " + code + " is " + firstClosingBracket); int secondOpeningBracket = firstClosingBracket + 1; int secondClosingBracket = code.indexOf('+', secondOpeningBracket); Serial.println("The Second index of the second ; in the string " + code + " is " + secondClosingBracket); String number = code.substring(9, 19); Serial.println(number); } void loop() { // put your main code here, to run repeatedly: }
1   لایک
 LinkBack URL
 About LinkBacks
  پاسخ با نقل قول
