ممنون. این کدشه. سه تا پین 11و12و13 رو از طریق وب پیج کنترل میکنیم.
#include <SoftwareSerial.h>
#define DEBUG true
SoftwareSerial esp8266(2,3); // make RX Arduino line is pin 2, make TX Arduino line is pin 3.
                             // This means that you need to connect the TX line from the esp to the Arduino's pin 2
                             // and the RX line from the esp to the Arduino's pin 3
  esp8266.begin(9600); // your esp's baud rate might be different
  pinMode(11,OUTPUT);
  digitalWrite(11,LOW);
  pinMode(12,OUTPUT);
  digitalWrite(12,LOW);
  pinMode(13,OUTPUT);
  digitalWrite(13,LOW);
  sendData("AT+RST\r\n",2000,DEBUG); // reset module
  sendData("AT+CWMODE=2\r\n",1000,DEBUG); // configure as access point
  sendData("AT+CIFSR\r\n",1000,DEBUG); // get ip address
  sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
  sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
  if(esp8266.available()) // check if the esp is sending a message
    if(esp8266.find("+IPD,"))
     delay(1000); // wait for the serial buffer to fill up (read all the serial data)
     // get the connection id so that we can then disconnect
     int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
                                           // the ASCII decimal value and 0 (the first decimal number) starts at 48
     esp8266.find("pin="); // advance cursor to "pin="
     int pinNumber = (esp8266.read()-48)*10; // get first number i.e. if the pin 13 then the 1st number is 1, then multiply to get 10
     pinNumber += (esp8266.read()-48); // get second number, i.e. if the pin number is 13 then the 2nd number is 3, then add to the first number
     digitalWrite(pinNumber, !digitalRead(pinNumber)); // toggle pin
     // make close command
     String closeCommand = "AT+CIPCLOSE=";
     closeCommand+=connectionId; // append connection id
     closeCommand+="\r\n";
     sendData(closeCommand,1000,DEBUG); // close connection
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    esp8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(esp8266.available())
        // The esp has data so display its output to the serial window
        char c = esp8266.read(); // read the next character.
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
