بسیار هم ماژول خوبیه
#include <SoftwareSerial.h>
SoftwareSerial SIM900(2, 3);
#define GSMReset 5
  Serial.begin(9600); // for serial monitor
  SIM900.begin(9600); // for GSM shield
  gsmPower();
  gsmConfig();
  commandDetect();
  smsProcess();
void gsmConfig() {
  pinMode(GSMReset, OUTPUT);
  sendCommand("AT+CMGF=1\r", 100); // set SMS mode to text
  sendCommand("AT+CNMI=2,2,0,0,0\r", 100);
  sendCommand("AT+CFUN=1", 2000);
  sendCommand("AT+CREG?", 1000);
  Serial.println("The end of Config process");
  Serial.println("Ensert\n 'd' for dial \n 'e' for english sms \n 'f' for farsi sms");
void showSms() {
  char incoming_char = 0;
  if (SIM900.available() > 0)
    incoming_char = SIM900.read(); //Get the character from the cellular serial port.
    Serial.print(incoming_char); //Print the incoming character to the terminal.
void smsProcess() {
    if (incoming_char == 'H')
      delay(10);
      Serial.print("horaaaaaaaaaaaaaaaaaaay");
void gsmPower() {
  Serial.println("Turning GSM ON");
  digitalWrite(GSMReset, HIGH);
  delay(10);
  digitalWrite(GSMReset, LOW);
  delay(100);
  delay(7000);
  Serial.println("config process...");
void sendCommand(String cmd, int t)
  SIM900.println(cmd);
  delay(t);
  readSerial();
void readSerial() {
  while (SIM900.available())
    Serial.write(SIM900.read());
void dialNumber(String number) {
  Serial.println("Dialing...");
  sendCommand("ATD" + number + ";", 100);
  Serial.println("End of Dial process");
  delay(2000);
void ensms()
  Serial.println("Sending SMS");
  sendCommand("AT+CSCS=\"IRA\"", 200);
  sendCommand("AT+CMGF=1", 200);
  sendCommand("AT+CSMP=17,167,0,0", 200);
  sendCommand("AT+CMGS=\"09331424592\"", 500);
  sendCommand("Salam\r\n AftabRayaneh !\x1A", 0);
  Serial.println("End of English SMS process");
  delay(2000);
void farsisms()
  sendCommand("AT+CSCS=\"HEX\"", 100);
  sendCommand("AT+CMGF=1", 100);
  sendCommand("AT+CSMP=17,167,0,8", 100);
  sendCommand("AT+CMGS=\"+09331424592\"", 500);
  sendCommand("0633064406270645060C002006220641062A0627062800200631062706CC062706460647\x1A", 0);
  Serial.println("End of Persian SMS process");
  delay(2000);
void commandDetect() {
  if (Serial.available() > 0)
    char data = Serial.read();
    switch (data)
      case 'd' : dialNumber("09331424592");
        break;
      case 'e' : ensms();
        break;
      case 'f' : farsisms();
        break;
این کده که خیلی پیچیده و قاطیه هیچی ازش نمیفهمم میشه یه کد ساده بدید که مثلا وقتی یه پایه ورودی فعال شد یه اس سند کنه یا اگه اس بهش سند شد پایه 13 رو ال ای دیشو روشن کنه !؟ یه کدی که خودتون تست کرده باشید که ببینم اگر واسه من جواب نداد بگردم ببینم عیب کارم کجاس . اخه تو بحث سخت افزارش خیلی حساسیت نشون دادم حتی واسه خود ماژول یه کاهنده قابل تنظیم گرفتم گذاشتم و دقیقا 4ولت رو براش تنظیم کردم زمینشم با اردوینو یکی کردم و... فقط یه تیکه کد ساده واسه فعال کردن یه پایه یا برعکسش بهم بدید تا خودم برم رووش کار کنم ببینم عیب کارم کجاس. ممنونم
