ترجمه ی بخش های زیر از Tutorial با من
LiquidCrystal Library
Hello World: displays "hello world!" and the seconds since reset.
Blink: control of the block-style cursor.
Cursor: control of the underscore-style cursor.
Display: quickly blank the display without losing what's on it.
TextDirection: control which way text flows from the cursor.
Scroll: scroll text left and right.
Serial input: accepts serial input, displays it.
SetCursor: set the cursor position.
Autoscroll: shift text right and left.
SPI Library
BarometricPressureSensor: read air pressure and temperature from a sensor using the SPI protocol.
SPIDigitalPot: control a AD5206 digital potentiometer using the SPI protocol.
Servo Library
Knob: control the shaft of a servo motor by turning a potentiometer.
Sweep: sweeps the shaft of a servo motor back and forth.
Software Serial Library
Software Serial Example: how to use the SoftwareSerial Library...Because sometimes one serial port just isn't enough!
Two Port Receive: how to work with multiple software serial ports.
Stepper Library
Motor Knob: control a highly accurate stepper motor using a potentiometer.
Wire Library
SFRRanger_reader: read a Devantech SRFxx ultra-sonic range finder using I2C communication.
digital_potentiometer: control a AD5171 digital pot using the Wire Library.
master reader/slave sender: set up two (or more) arduino boards to share information via a master reader/slave sender configuration.
master writer/slave reader: allow two (or more) arduino boards to share information using a master writer/slave reader set up.
WiFi Library
ConnectNoEncryption : Demonstrates how to connect to an open network
ConnectWithWEP : Demonstrates how to connect to a network that is encrypted with WEP
ConnectWithWPA : Demonstrates how to connect to a network that is encrypted with WPA2 Personal
ScanNetworks : Displays all WiFi networks in range
WiFiChatServer : Set up a simple chat server
WiFiPachubeClient : connect to pachube.com, a free datalogging site
WiFiPachubeClientString: send strings to pachube.com
WiFiTwitterClient : A Twitter client with Strings
WiFiWebClient : Connect to a remote webserver
WiFiWebClientRepeating: Repeatedly make HTTP calls to a server
WiFiWebServer : Serve a webpage from the WiFi shield
Esplora Library
Beginners
EsploraBlink : Blink the Esplora's RGB LED
EsploraAccelerometer : Read the values from the accelerometer
EsploraJoystickMouse : Use the Esplora's joystick to control the cursor on your computer
EsploraLedShow : Use the Joystick and slider to create a light show with the LED
EsploraLedShow2 : Use the Esplora's microphone, linear potentiometer, and light sensor to change the color of the onboard LED.
EsploraLightCalibrator : Read the values from the accelerometer
EsploraMusic : Make some music with the Esplora
EsploraSoundSensor : Read the values from the Esplora's microphone
EsploraTemperatureSensor : Read the temperature sensor and get the temperature in in Farhenheit or Celsius.
25 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
تجارب خودمو در اختیار دوستان بزارم. خوشحال می شم که دوستان و آقای SPARK هم اگر ایرادی اشکالی نگارشی و ... دیدند به من اطلاع بدن من در اسرع وقت اصلاح خواهم کرد فقط
