نمایش نتایج: از 1 به 10 از 10
  • 1 Post By am.koshesh@gmail.com
موضوع: پروگرام کردن avr با آردوینو uno
    سلام خدمت اساتید و بقیه دوستان محترم
    یه سر به این لینک پایین پیام بزنید . آموزش ساخت پروگرامر برای attiny13 هست .
    تک تک مراحل رو مثل خودش انجام دادم ولی در آخرین مرحله که آی سی رو میخواهیم پروگرام کنیم این ارور رو میده
    Arduino: 1.6.9 (Windows 10), Board: "ATtiny13 (internal 9.6 MHz clock)"
    Warning: Board attiny-Arduino1:attiny:attiny44-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-8
    Warning: Board attiny-Arduino1:attiny:attiny85 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85
    Warning: Board attiny-Arduino1:attiny:attiny45 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45
    Warning: Board attiny-Arduino1:attiny:attiny44 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44
    Warning: Board attiny-Arduino1:attiny:attiny85-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-20
    Warning: Board attiny-Arduino1:attiny:attiny84-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-20
    Warning: Board attiny-Arduino1:attiny:attiny13 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY13
    Warning: Board attiny-Arduino1:attiny:attiny44-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-20
    Warning: Board attiny-Arduino1:attiny:attiny84-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-8
    Warning: Board attiny-Arduino1:attiny:attiny45-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-20
    Warning: Board attiny-Arduino1:attiny:attiny45-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-8
    Warning: Board attiny-Arduino1:attiny:attiny84 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84
    Warning: Board attiny-Arduino1:attiny:attiny85-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-8
    recipe.preproc.macros pattern is missing
    Error compiling for board ATtiny13 (internal 9.6 MHz clock).
    اینم لینک مطلب
    Programming an ATTiny13A using Arduino & servo interpreter - All
    ممنون میشم راهنمایی کنید
    الووووووووووو
    الووووووووووو
    بله بفرمائید...
    نقل قول نوشته اصلی توسط meysamam نمایش پست ها
    بله بفرمائید...
    ببخشید که سوال پرسیده بودم شرمنده ام کردید داغونم کردید یعنی له له شدم
    داداش ببخشید سوالم رو قبل از الووووووووووووووو فرموده بودم
    آی موترم .... طبق او لینکی که گذاشته بودید من تست کردم و یک آردینو دیگرو پروگرام کرد بدون مشکل شاید شما توی اتصالات یا یک مشکل دیگه داشته باشید
    ic attiny13 پروگرام کردید؟؟؟؟؟؟؟؟؟؟؟؟؟
    من اصلا آپلود نمیکنم فقط VRIFY رو میزنم تا برنامه چک بشه ولی همین مرحله ارور میده فایل های مربوط به ATTINY هم از چند سایت مختلط گرفتم و تو آدرس Arduino>Hardware اکسترکت کردم ولی بازم مثل اینکه آی سیم رو نمیشناسه (نرم افزاری . چون اصلا آپلود نمیکنم که لازم به اتصال باشه)
    اور:
    Arduino: 1.8.1 (Windows 10), Board: "ATtiny13 (internal 9.6 MHz clock)"
    The current selected board needs the core 'arduino:arduino' that is not installed.
    Detecting libraries used...
    امکانش هست بخاطر سیستم ویروسیم باشه؟
نام: Untitled.jpg
مشاهده: 362
حجم: 90.1 کیلو بایت
    ویرایش توسط am.koshesh@gmail.com : 02-04-2017 در ساعت 07:46 PM
    اور:
نام: Untitled.jpg
مشاهده: 362
حجم: 90.1 کیلو بایت
    من روال کار توضیح میدم...
    1- باز کردن ArduinoISP در پوشه Examples
    کامپایل کردن پروژه روی یک برد آردینو
    بعد استفاده از برد آردینو به عنوان پروگرامر
    بله اینو میدونم !
    مشکلم حل شد . اینم لینکش
    Apr 2018
    سلام بزرگواران خسته نباشین من یه مشکل پیش اومده برامانگاری برنامه داخلی ای سی اردوینو قاطی کرده اصلا هیچی روش اپلود نمیشه ایا میشه برنامه رو پاک کرد دوباره زد روش
