سلام این خط چی داره میگه؟ ممنون میشم مفهومی توضیح بدین...
این علامت & چیه ؟
(radio.available(&pipeNum)
کد:byte pipeNum = 0; //variable to hold which reading pipe sent data byte gotByte = 0; //used to store payload from transmit module while(radio.available(&pipeNum)){ //Check if recieved data radio.read( &gotByte, 1 ); //read one byte of data and store it in gotByte variable Serial.print("Recieved guess from transmitter: "); Serial.println(pipeNum); //print which pipe or transmitter this is from Serial.print("They guess number: "); Serial.println(gotByte); //print payload or the number the transmitter guessed if(gotByte != daNumber) { //if true they guessed wrong Serial.println("Fail!! Try again."); } else { //if this is true they guessed right if(sendCorrectNumber(pipeNum)) Serial.println("Correct! You're done."); //if true we successfully responded else Serial.println("Write failed"); //if true we failed responding } Serial.println(); }
1 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
