نمایش نتایج: از 1 به 5 از 5
  • 2 Post By magmagmary
  • 1 Post By dogdoor313
موضوع: ماژول صفحه نمایش ماتریسی 16 * 16 تک رنگ
نام: 00100-071.jpg
مشاهده: 358
حجم: 47.1 کیلو بایت
    نمونه کد :
      * Show messages on an 8x8 led matrix,
      * scrolling from right to left.
      * Uses FrequencyTimer2 library to
      * constantly run an interrupt routine
      * at a specified frequency. This
      * refreshes the display without the
      * main loop having to do anything.
    #include <FrequencyTimer2.h>
    #define SPACE { \
         {0, 0, 0, 0, 0, 0, 0, 0},  \
         {0, 0, 0, 0, 0, 0, 0, 0} \
    #define H { \
         {0, 1, 0, 0, 0, 0, 1, 0}, \
         {0, 1, 1, 1, 1, 1, 1, 0}, \
         {0, 1, 0, 0, 0, 0, 1, 0}  \
    #define E  { \
         {0, 1, 0, 0, 0, 0, 0, 0}, \
         {0, 1, 1, 1, 1, 1, 1, 0}  \
    #define L { \
    #define O { \
         {0, 0, 0, 1, 1, 0, 0, 0}, \
         {0, 0, 1, 0, 0, 1, 0, 0}, \
         {0, 0, 0, 1, 1, 0, 0, 0}  \
    byte col = 0;
    byte leds[8][8];
    // pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
    int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
    // col[xx] of leds = pin yy on led matrix
    int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
    // row[xx] of leds = pin yy on led matrix
    int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
    const int numPatterns = 6;
    byte patterns[numPatterns][8][8] = {
       H,E,L,L,O,SPACE
    int pattern = 0;
       // sets the pins as output
       for (int i = 1; i <= 16; i++) {
         pinMode(pins[i], OUTPUT);
      // set up cols and rows
       for (int i = 1; i <= 8; i++) {
         digitalWrite(cols[i - 1], LOW);
         digitalWrite(rows[i - 1], LOW);
      clearLeds();
      // Turn off toggling of pin 11
       FrequencyTimer2::disable();
       // Set refresh rate (interrupt timeout period)
       FrequencyTimer2::setPeriod(2000);
       // Set interrupt routine to be called
       FrequencyTimer2::setOnOverflow(display);
      setPattern(pattern);
         pattern = ++pattern % numPatterns;
         slidePattern(pattern, 60);
    void clearLeds() {
       // Clear display array
       for (int i = 0; i < 8; i++) {
         for (int j = 0; j < 8; j++) {
           leds[i][j] = 0;
    void setPattern(int pattern) {
           leds[i][j] = patterns[pattern][i][j];
    void slidePattern(int pattern, int del) {
       for (int l = 0; l < 8; l++) {
         for (int i = 0; i < 7; i++) {
             leds[j][i] = leds[j][i+1];
           leds[j][7] = patterns[pattern][j][0 + l];
         delay(del);
    // Interrupt routine
    void display() {
       digitalWrite(cols[col], LOW);  // Turn whole previous column off
       col++;
       if (col == 8) {
         col = 0;
       for (int row = 0; row < 8; row++) {
         if (leds[col][7 - row] == 1) {
           digitalWrite(rows[row], LOW);  // Turn on this led
         else {
           digitalWrite(rows[row], HIGH); // Turn off this led
       digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
    کتابخانه در فایل ضمیمه
