نمایش نتایج: از 1 به 8 از 8
موضوع: ماژول نمایشگر lcd 128 x 64 دارای ارتباط i2c
    ماژول نمایشگر LCD 128 X 64 دارای ارتباط I2C
    ترتیب اتصال پینها :
    Arduino LCD
    6 LED
    7 A0
    8 RST
    9 CS
    11 SDA
    13 SCL
    GND GND
    VCC VCC
    نمونه کد :
    #include <U8glib.h>
    byte ledBacklight = 150;
    const byte lcdLED = 6;                   // LED Backlight
    const byte lcdA0 = 7;                    // Data and command selections. L: command  H : data
    const byte lcdRESET = 8;                 // Low reset
    const byte lcdCS = 9;                    // SPI Chip Select (internally pulled up), active low
    const byte lcdMOSI = 11;                 // SPI Data transmission
    const byte lcdSCK = 13;                  // SPI Serial Clock
    const byte bufferSize = 60;//32
    // SW SPI:
    //U8GLIB_MINI12864_2X u8g(lcdSCK, lcdMOSI, lcdCS, lcdA0, lcdRESET);
    // HW SPI:
    U8GLIB_MINI12864_2X u8g(lcdCS, lcdA0, lcdRESET);
    const byte LINE_MAX = 30;          // setup input buffer
    byte line_buf[LINE_MAX];
    byte line_pos = 0;
    const byte ROW_MAX = 12;           // setup a text screen to support scrolling
    byte screen[ROW_MAX][LINE_MAX];
    byte rows, cols;
    const byte LINE_PIXEL_HEIGHT = 7;  // line height, which matches the selected font (5x7)
    // Print character arrays to console
    void u8g_print(char* theString) {
      char ch;
      byte i = 0;
      while ((ch = theString[i++]) != '\0') {
    	read_line(ch);
    // Print character arrays with a new line at the end
    void u8g_println(char* theString) {
      u8g_print(theString);
      read_line('\r');
    // Print character arrays saved in program memory to console
    void u8g_print_P( const char  *theString) {
      char ch;
      while ((ch = pgm_read_byte(theString++)) != '\0') {
    	read_line(ch);
    // Print character arrays saved in program memory with a new line at the end
    void u8g_println_P(const char  *theString) {
      u8g_print_P(theString);
      read_line('\r');
    // Clear entire screen, called during setup
    void clear_screen(void) {
      byte i, j;
      for( i = 0; i < ROW_MAX; i++ )
        for( j = 0; j < LINE_MAX; j++ )
          screen[i][j] = 0;
    // Append a line to the screen, scroll up
    void add_line_to_screen(void) {
      byte i, j;
        for( i = 0; i < rows-1; i++ )
          screen[i][j] = screen[i+1][j];
        screen[rows-1][j] = line_buf[j];
    // U8GLIB draw procedure: output the screen
    void draw(void) {
      byte i, y;
      // graphic commands to redraw the complete screen are placed here
      y = 0;       // reference is the top left -1 position of the string
      y--;           // correct the -1 position of the drawStr
      for( i = 0; i < rows; i++ )
        u8g.drawStr( 0, y, (char *)(screen[i]));
        y += u8g.getFontLineSpacing();
    void exec_line(void) {
      // Add the line to the screen
      add_line_to_screen();
      // U8GLIB picture loop
      u8g.firstPage();
      do {
        draw();
      } while( u8g.nextPage() );
    // Clear current input buffer
    void reset_line(void) {
          line_pos = 0;
          line_buf[line_pos] = '\0';
    // Add a single character to the input buffer
    void char_to_line(char c) {
          line_buf[line_pos] = c;
          line_pos++;
    // Handle new console character
    void read_line(char c) {
      if ( line_pos >= cols-1 ) {
        exec_line();
        reset_line();
        char_to_line(c);
      else if ( c == '\n' ) {
        // ignore '\n'
      else if ( c == '\r' ) {
        exec_line();
        reset_line();
      else {
        char_to_line(c);
    // From http://playground.arduino.cc/Code/AvailableMemory
    int freeRam () {
      extern int __heap_start, *__brkval;
      int v;
      return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
        char buf[bufferSize];
        // Turn on LED backlight
        analogWrite(lcdLED, ledBacklight);
        // Setup U8glib
        u8g.begin();
        u8g.setFont(u8g_font_5x7);    // Set font for the console window
        u8g.setFontPosTop();          // Set upper left position for the string draw procedure
        // Calculate the number of rows for the display
        rows = u8g.getHeight() / u8g.getFontLineSpacing();
        if ( rows > ROW_MAX )
          rows = ROW_MAX;
        // Estimate the number of columns for the display
        cols = u8g.getWidth() / u8g.getStrWidth("m");
        if ( cols > LINE_MAX-1 )
          cols = LINE_MAX-1;
        clear_screen();               // Clear screen
        delay(1000);                  // Delay
        reset_line();                 // Clear input buffer
        // Print some information
        u8g_println_P(PSTR("U8glib Fio Console"));
        u8g_println_P(PSTR("semifluid.com"));
        u8g_println_P(PSTR(""));
        u8g_println_P(PSTR("Starting..."));
        u8g_print_P(PSTR("Free Memory: "));
        String(freeRam(),DEC).toCharArray(buf, sizeof(buf));u8g_println(buf);
    int i = 0;
        // Start timer
        unsigned long theStart = micros();
        // Display an incrementing counter
        String(i,DEC).toCharArray(buf, sizeof(buf));u8g_print(buf);
        u8g_print_P(PSTR("-"));
        String(i,HEX).toCharArray(buf, sizeof(buf));u8g_print(buf);
        String(i,BIN).toCharArray(buf, sizeof(buf));u8g_print(buf);
        i++;
        // Approximate time in microseconds that it took to display the information
        unsigned long theEnd = micros();
        unsigned long delta = theEnd - theStart;
        String(delta,DEC).toCharArray(buf, sizeof(buf));u8g_println(buf);
        // No delay, so loop as quickly as possible
    Jun 2016
    ایران عزیر
    چرا تو نمونه کد از ارتباط spi استفاده شده
    Aug 2016
    سلام . آقا این ال سی دی اصلا روی UNO جواب میده؟ من هر کاری میکنم جواب نمیگیرم
    فقط وقتی نمونه کدی رو که شما نوشتین مینویسم و اپلود میکنم یه مشت اعداد و ارقام با سرعت روی صفحه میان . ولی از طریق فایل پیوست شده کتابخونه و مثالهاش فقط ارور میده .
    خواهش میکنم راهنمایی بفرمایید .
    این هم دو نمونه از ارورها
    نوع اول
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    نوع دوم
    exit status 1
    'u8g' was not declared in this scope
    قابل توجه که من هیچگونه تغییری در مثالها ندادم ولی باز هم این ارور رو میده
    این فایلها اطلاعاتی هستن که سایت رفرنس در اختیار قرار داده:
    Oct 2016
    خیلی ممنون از کدی که زحمت کشیدید
    عینا توی arduino uno کپی و تست شد
    elf
    elf آنلاین نیست.
    سلام من آردینو کار نمیکنم ولی اینو راه انداختم بکارتون امد بگید کمک کنمبرای دیدن سایز بزرگ روی عکس کلیک کنید
نام: 13022017008.jpg
مشاهده: 297
حجم: 84.8 کیلو بایت
    ویرایش توسط elf : 02-15-2017 در ساعت 07:47 PM
    Mar 2017
    این که بازم ۸ تا پورت استفاده میکنه!!!
    راه افتاد ولی من اگه قرار بود ۸ تا پورت اشغال کنم که این ال سی دی رو نمی خریدم!!!!
    Jan 2014
    سلام مهندس لطف میکنی کدت رو به اشتراک بذاری؟
