نمایش نتایج: از 11 به 20 از 38
Like Tree6 لایک
موضوع: ماژول دوربین رنگی jpeg با ربط ttl سریال
    May 2013
نام: 397-02.jpg
مشاهده: 504
حجم: 93.1 کیلو بایت
    #include <Adafruit_VC0706.h> #include <SD.h> #include <SPI.h> // comment out this line if using Arduino V23 or earlier #include <SoftwareSerial.h> // uncomment this line if using Arduino V23 or earlier // #include <NewSoftSerial.h> // SD card chip select line varies among boards/shields: // Adafruit SD shields and modules: pin 10 // Arduino Ethernet shield: pin 4 // Sparkfun SD shield: pin 8 // Arduino Mega w/hardware SPI: pin 53 // Teensy 2.0: pin 0 // Teensy++ 2.0: pin 20 #define chipSelect 4 // Pins for camera connection are configurable. // With the Arduino Uno, etc., most pins can be used, except for // those already in use for the SD card (10 through 13 plus // chipSelect, if other than pin 10). // With the Arduino Mega, the choices are a bit more involved: // 1) You can still use SoftwareSerial and connect the camera to // a variety of pins...BUT the selection is limited. The TX // pin from the camera (RX on the Arduino, and the first // argument to SoftwareSerial()) MUST be one of: 62, 63, 64, // 65, 66, 67, 68, or 69. If MEGA_SOFT_SPI is set (and using // a conventional Arduino SD shield), pins 50, 51, 52 and 53 // are also available. The RX pin from the camera (TX on // Arduino, second argument to SoftwareSerial()) can be any // pin, again excepting those used by the SD card. // 2) You can use any of the additional three hardware UARTs on // the Mega board (labeled as RX1/TX1, RX2/TX2, RX3,TX3), // but must specifically use the two pins defined by that // UART; they are not configurable. In this case, pass the // desired Serial object (rather than a SoftwareSerial // object) to the VC0706 constructor. // Using SoftwareSerial (Arduino 1.0+) or NewSoftSerial (Arduino 0023 & prior): #if ARDUINO >= 100 // On Uno: camera TX connected to pin 2, camera RX to pin 3: SoftwareSerial cameraconnection = SoftwareSerial(2, 3); // On Mega: camera TX connected to pin 69 (A15), camera RX to pin 3: //SoftwareSerial cameraconnection = SoftwareSerial(69, 3); #else NewSoftSerial cameraconnection = NewSoftSerial(2, 3); #endif Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection); // Using hardware serial on Mega: camera TX conn. to RX1, // camera RX to TX1, no SoftwareSerial object is required: //Adafruit_VC0706 cam = Adafruit_VC0706(&Serial1); void setup() { // When using hardware SPI, the SS pin MUST be set to an // output (even if not connected or used). If left as a // floating input w/SPI on, this can cause lockuppage. #if !defined(SOFTWARE_SPI) #if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega #else if(chipSelect != 10) pinMode(10, OUTPUT); // SS on Uno, etc. #endif #endif Serial.begin(9600); Serial.println("VC0706 Camera snapshot test"); // see if the card is present and can be initialized: if (!SD.begin(chipSelect)) { Serial.println("Card failed, or not present"); // don't do anything more: return; } // Try to locate the camera if (cam.begin()) { Serial.println("Camera Found:"); } else { Serial.println("No camera found?"); return; } // Print out the camera version information (optional) char *reply = cam.getVersion(); if (reply == 0) { Serial.print("Failed to get version"); } else { Serial.println("-----------------"); Serial.print(reply); Serial.println("-----------------"); } // Set the picture size - you can choose one of 640x480, 320x240 or 160x120 // Remember that bigger pictures take longer to transmit! //cam.setImageSize(VC0706_640x480); // biggest cam.setImageSize(VC0706_320x240); // medium //cam.setImageSize(VC0706_160x120); // small // You can read the size back from the camera (optional, but maybe useful?) uint8_t imgsize = cam.getImageSize(); Serial.print("Image size: "); if (imgsize == VC0706_640x480) Serial.println("640x480"); if (imgsize == VC0706_320x240) Serial.println("320x240"); if (imgsize == VC0706_160x120) Serial.println("160x120"); Serial.println("Snap in 3 secs..."); delay(3000); if (! cam.takePicture()) Serial.println("Failed to snap!"); else Serial.println("Picture taken!"); // Create an image with the name IMAGExx.JPG char filename[13]; strcpy(filename, "IMAGE00.JPG"); //strcpy(filename, "IMAGE00.JPG"); for (int i = 0; i < 100; i++) { filename[5] = '0' + i/10; filename[6] = '0' + i%10; // create if does not exist, do not open existing, write, sync after write if (! SD.exists(filename)) { break; } } // Open the file for writing File imgFile = SD.open(filename, FILE_WRITE); // Get the size of the image (frame) taken uint16_t jpglen = cam.frameLength(); Serial.print("Storing "); Serial.print(jpglen, DEC); Serial.print(" byte image."); int32_t time = millis(); pinMode(8, OUTPUT); // Read all the data up to # bytes! byte wCount = 0; // For counting # of writes while (jpglen > 0) { // read 32 bytes at a time; uint8_t *buffer; uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups! buffer = cam.readPicture(bytesToRead); imgFile.write(buffer, bytesToRead); if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up Serial.print('.'); wCount = 0; } //Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes"); jpglen -= bytesToRead; } imgFile.close(); time = millis() - time; Serial.println("done!"); Serial.print(time); Serial.println(" ms elapsed"); } void loop() { }
    خیلی ممنون ، پست مفیدی هست
    سلام به همگی
    یه سوال داشتم
    این دوربین نیازی به مکس 232 و ... برای اتصال به میکرو کنترلر که نداره؟
    Sep 2014
    سلام.
    من تمام کارایی که گفتید رو انجام دادم منتهی عکسی دریافت نمیکنم فقط کد هگزادسیمال نمایش داده میشه
    اینم عکس
    ماژول دوربین م از آفتاب رایانه خریداری کرده ام.لطفا راهنمایی کنید من زیاد با اردوینو اشنایی ندارم اما برنامه نویسی بیسیک در سطح خوبی بلدم...
    May 2013
    اگه کد بالا رو استفاده کردید عکس تو کارت حافظه ذخیره میشه
    سلام.
    در خط اول برنامه اشاره به پوشه یا برنامه ای بنام SoftwareSerial.h> کرده که در کدها وجود نداره. لطفاً راهنمایی فرمائید.
    Question کدام دوربین؟
    سلام من بین این دوربین با دوربینی که vc0706 چیپشه دو دلم
    کدیم که تو چنتا پست بالاتر قرار گرفته ماله اون سری هست
    دیتاشیت هم من هر چه گشتم نیست!
    یک چیز دیگه اینکه پشت دوربین max3232 هست و ارتباط دوربین rs232 هست
    پس چطوری بدون max232 گفتین وصل میشه؟ :|
    چون با کتابخونه SoftwareSerial کار میکنه اینطوریه؟
    در ضمن جای پایه های تصویرم اشتباه نیس
    کدشو نگاه کنین متوجه میشید
    کسی تا حالا از این دوربین با همین کدها تصویر گرفته؟
    مشکلی نداره؟
    ویرایش توسط aminta : 01-29-2015 در ساعت 11:48 AM
  8. #18
    Jul 2015
    من این برنامه رو روی آردوینو ریختم و دقیقاً سیم بندی رو اجرا کردم ولی هیچ جوابی بهم نداد!
    روی پورت سریال نرم افزار آردوینو در هنگام اجرا فقط مثل اینکه enter میخوره و به خط بعد میره و هیچ کدی دریافت نشد
    احتمال داره ماژول قبل از اینکه دستم برسه خراب بوده باشه؟
    Jun 2016
    کسی هست که از این دوربین استفاده کرده باشه و بتونه نمونه عکسی که گرفته را بگذاره؟من می خوام ببینم در عمل کیفیتش چجوریه
    خیلی ممنون
  10. #20
    نقل قول نوشته اصلی توسط Arduinoo نمایش پست ها
    خیلی ممنون
    این نمونه عکس های خود فروشنده هست:
نام: 1.jpg
مشاهده: 168
حجم: 52.6 کیلو بایت
نام: 2.jpg
مشاهده: 153
حجم: 59.4 کیلو بایت
