نمایش نتایج: از 1 به 6 از 6
موضوع: شیلد درایور cnc ورژن 3
    نمونه کد اردوینو :
    # define EN 8 / / stepper motor enable , active low
    # define X_DIR 5 / / X -axis stepper motor direction control
    # define Y_DIR 6 / / y -axis stepper motor direction control
    # define Z_DIR 7 / / z axis stepper motor direction control
    # define X_STP 2 / / x -axis stepper control
    # define Y_STP 3 / / y -axis stepper control
    # define Z_STP 4 / / z -axis stepper control
    / / Function : step . function: to control the direction of the stepper motor , the number of steps .
    / / Parameters : dir direction control , dirPin corresponding stepper motor DIR pin , stepperPin corresponding stepper motor " step " pin , Step number of step of no return value.
    void step (boolean dir, byte dirPin, byte stepperPin, int steps)
    digitalWrite (dirPin, dir);
    delay (50);
    for (int i = 0; i digitalWrite (stepperPin, HIGH);
    delayMicroseconds (800);
    digitalWrite (stepperPin, LOW);
    void setup () {/ / The stepper motor used in the IO pin is set to output
    pinMode (X_DIR, OUTPUT); pinMode (X_STP, OUTPUT);
    pinMode (Y_DIR, OUTPUT); pinMode (Y_STP, OUTPUT);
    pinMode (Z_DIR, OUTPUT); pinMode (Z_STP, OUTPUT);
    pinMode (EN, OUTPUT);
    digitalWrite (EN, LOW);
    void loop () {
    step (false, X_DIR, X_STP, 200); / / X axis motor reverse 1 ring, the 200 step is a circle.
    step (false, Y_DIR, Y_STP, 200); / / y axis motor reverse 1 ring, the 200 step is a circle.
    step (false, Z_DIR, Z_STP, 200); / / z axis motor reverse 1 ring, the 200 step is a circle.
    delay (1000);
    step (true, X_DIR, X_STP, 200); / / X axis motor forward 1 laps, the 200 step is a circle.
    step (true, Y_DIR, Y_STP, 200); / / y axis motor forward 1 laps, the 200 step is a circle.
    step (true, Z_DIR, Z_STP, 200); / / z axis motor forward 1 laps, the 200 step is a circle.
    delay (1000);
    دستور for در تابع step ناقص نوشته شده است. برنامه کامل در این لینک موجود هست.
    ویرایش توسط farrokh : 12-13-2016 در ساعت 05:32 PM
    Banned
    Sep 2016
    Usa
    #define EN 8 // stepper motor enable , active low
    #define X_DIR 5 // X -axis stepper motor direction control
    #define Y_DIR 6 // y -axis stepper motor direction control
    #define Z_DIR 7 // z axis stepper motor direction control
    #define X_STP 2 // x -axis stepper control
    #define Y_STP 3 // y -axis stepper control
    #define Z_STP 4 // z -axis stepper control
    // Function : step . function: to control the direction of the stepper motor , the number of steps .
    // Parameters : dir direction control , dirPin corresponding stepper motor DIR pin , stepperPin corresponding stepper motor " step " pin , Step number of step of no return value.
    delay (50);
    for (int i = 0; i < steps; i++) {
    void setup () {// The stepper motor used in the IO pin is set to output
    void loop () {
    step (false, X_DIR, X_STP, 200); // X axis motor reverse 1 ring, the 200 step is a circle.
    step (false, Y_DIR, Y_STP, 200); // y axis motor reverse 1 ring, the 200 step is a circle.
    step (false, Z_DIR, Z_STP, 200); // z axis motor reverse 1 ring, the 200 step is a circle.
    delay (1000);
    step (true, X_DIR, X_STP, 200); // X axis motor forward 1 laps, the 200 step is a circle.
    step (true, Y_DIR, Y_STP, 200); // y axis motor forward 1 laps, the 200 step is a circle.
    step (true, Z_DIR, Z_STP, 200); // z axis motor forward 1 laps, the 200 step is a circle.
    delay (1000);
    من میخوام همراه با کد بالا سرعت استپ موتور رو با دستور setSpeed هم کنترل کنم. نمیدونم چطوری باید این دستور و شی مورد نظر رو بنویسم. ممنون میشم کمک کنید.
    نقل قول نوشته اصلی توسط farrokh نمایش پست ها
    void step(boolean dir, byte dirPin, byte stepperPin, int steps, long speed)
    digitalWrite(dirPin, dir);
    delay(50);
    digitalWrite(stepperPin, HIGH);
    delayMicroseconds(800);
    digitalWrite(stepperPin, LOW);
    delayMicroseconds(speed);
    pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
    pinMode(EN, OUTPUT);
    digitalWrite(EN, LOW);
    step(false, X_DIR, X_STP, 200. 15); / / X axis motor reverse 1 ring, the 200 step is a circle.
    Jun 2017
    سلام من یه استپر موتور 12 ولت 5 سیمه 28BYJ-48 دارم و این شیلد رو با درایور Reprap A4988 برای دیدن سایز بزرگ روی عکس کلیک کنید
نام: Reprap-A4988 (3)-500x500.jpg
مشاهده: 288
حجم: 38.6 کیلو بایت
    ولی روی این شیلد فقط جای چهار تا سیم داره ، چکار کنم ؟ ممنون
