موضوع: موتور میکرو سروو H512 Tower Pro SG90
    نمونه کد آردوینو با کتابخانه سروو :
    #include servo.h  //add '<' and '>' before and after servo.h
    int servoPin = 9;
    Servo servo;
    int servoAngle = 0;   // servo position in degrees
      servo.attach(servoPin);
    //control the servo's direction and the position of the motor
       servo.write(45);      // Turn SG90 servo Left to 45 degrees
       delay(1000);          // Wait 1 second
       servo.write(90);      // Turn SG90 servo back to 90 degrees (center position)
       servo.write(135);     // Turn SG90 servo Right to 135 degrees
    //end control the servo's direction and the position of the motor
    //control the servo's speed
    //if you change the delay value (from example change 50 to 10), the speed of the servo changes
      for(servoAngle = 0; servoAngle < 180; servoAngle++)  //move the micro servo from 0 degrees to 180 degrees
        servo.write(servoAngle);
        delay(50);
      for(servoAngle = 180; servoAngle > 0; servoAngle--)  //now move back the micro servo from 0 degrees to 180 degrees
        delay(10);
      //end control the servo's speed
    نمونه سیم بندی اتصال سروو sg90 به برد آردوینو :
نام: Arduino-servo-motor-control_bb-e1452431548643.jpg
مشاهده: 741
حجم: 94.7 کیلو بایت
