#include <EEPROM.h>
uint addr = 0;
// fake data
struct {
uint val = 0;
char str[20] = "";
} data;
// commit 512 bytes of ESP8266 flash (for "EEPROM" emulation)
// this step actually loads the content (512 bytes) of flash into
// a 512-byte-array cache in RAM
EEPROM.begin(512);
// read bytes (i.e. sizeof(data) from "EEPROM"),
// in reality, reads from byte-array cache
// cast bytes into structure called data
EEPROM.get(addr,data);
Serial.println("Old values are: "+String(data.val)+","+String(data.str));
// fiddle with the data "read" from EEPROM
data.val += 5;
if ( strcmp(data.str,"hello") == 0 )
strncpy(data.str, "jerry",20);
strncpy(data.str, "hello",20);
// replace values in byte-array cache with modified data
// no changes made to flash, all in local byte-array cache
EEPROM.put(addr,data);
// actually write the content of byte-array cache to
// hardware flash. flash write occurs if and only if one or more byte
// in byte-array cache has been changed, but if so, ALL 512 bytes are
// written to flash
EEPROM.commit();
// clear 'data' structure
data.val = 0;
strncpy(data.str,"",20);
// reload data for EEPROM, see the change
// OOPS, not actually reading flash, but reading byte-array cache (in RAM),
// power cycle ESP8266 to really see the flash/"EEPROM" updated
Serial.println("New values are: "+String(data.val)+","+String(data.str));
