صفحه 7 از 11 نخستنخست ... 56789 ... آخرینآخرین
نمایش نتایج: از 61 به 70 از 110
Like Tree17 لایک
موضوع: سنسور جایرو و شتاب سنج سه محوره mpu6050 GY-521
  1. #61
    Oct 2015
    اینو تست کن :
    /* Author = helscream (Omer Ikram ul Haq)
      Last edit date = 2014-10-08
      Website: Arduino with MPU6050 and angle calculation – HobbyLogs
      Ver: 0.1 beta --- Start
      Ver: 0.2 beta --- Bug fixed for calculating "angle_y_accel" and "angle_x_accel" in "Gyro_header.ino" file
    #include <Wire.h>
    #include "gyro_accel.h"
    // Defining constants
    #define dt 20 // time difference in milli seconds
    #define rad2degree 57.3 // Radian to degree conversion
    #define Filter_gain 0.95 // e.g. angle = angle_gyro*Filter_gain + angle_accel*(1-Filter_gain)
    // Global Variables
    unsigned long t = 0; // Time Variables
    float angle_x_gyro = 0, angle_y_gyro = 0, angle_z_gyro = 0, angle _x_accel = 0, angle_y_accel = 0, angle_z_accel = 0, angle_x = 0, angle_y = 0, angle_z = 0;
    // Main Code
      Serial.begin(115200);
      Wire.begin();
      MPU6050_ResetWake();
      MPU6050_SetGains(0, 1); // Setting the lows scale
      MPU6050_SetDLPF(0); // Setting the DLPF to inf Bandwidth for calibration
      MPU6050_OffsetCal();
      MPU6050_SetDLPF(6); // Setting the DLPF to lowest Bandwidth
      Serial.print("gyro_x_scalled");
      Serial.print("\tgyro_y_scalled");
      Serial.print("\tgyro_z_scalled");
      Serial.print("\taccel_x_scalled");
      Serial.print("\taccel_y_scalled");
      Serial.print("\taccel_z_scalled");
      Serial.print("\tangle_x_gyro");
      Serial.print("\tangle_y_gyro");
      Serial.print("\tangle_z_gyro");
      Serial.print("\tangle_x_accel");
      Serial.print("\tangle_y_accel");
      Serial.print("\tangle_z_accel");
      Serial.print("\tangle_x");
      Serial.print("\tangle_y");
      Serial.print("\tangle_z");
      Serial.println("\tLoad");
      t = millis();
      int relaypin = 3;
      t = millis();
      MPU6050_ReadData();
      angle_x_gyro = (gyro_x_scalled * ((float)dt / 1000) + angle_x);
      angle_y_gyro = (gyro_y_scalled * ((float)dt / 1000) + angle_y);
      if (angle_y_gyro < 90) digitalWrite (relaypin, LOW);
      else digitalWrite (relaypin, HIGH);
      angle_z_gyro = (gyro_z_scalled * ((float)dt / 1000) + angle_z);
      angle_z_accel = atan(accel_z_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_x_scal led * accel_x_scalled))) * (float)rad2degree;
      angle_y_accel = -atan(accel_y_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree;
      angle_x_accel = atan(accel_x_scalled / (sqrt(accel_x_scalled * accel_x_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree;
      angle_x = Filter_gain * angle_x_gyro + (1 - Filter_gain) * angle_x_accel;
      angle_y = Filter_gain * angle_y_gyro + (1 - Filter_gain) * angle_y_accel;
      angle_z = Filter_gain * angle_z_gyro + (1 - Filter_gain) * angle_z_accel;
      Serial.print(gyro_x_scalled);
      Serial.print("\t");
      Serial.print(gyro_y_scalled);
      Serial.print("\t");
      Serial.print(gyro_z_scalled);
      Serial.print("\t");
      Serial.print(accel_x_scalled);
      Serial.print("\t");
      Serial.print(accel_y_scalled);
      Serial.print("\t");
      Serial.print(accel_z_scalled);
      Serial.print("\t");
      Serial.print(angle_x_gyro);
      Serial.print("\t");
      Serial.print(angle_y_gyro);
      Serial.print("\t");
      Serial.print(angle_z_gyro);
      Serial.print("\t");
      Serial.print(angle_x_accel);
      Serial.print("\t");
      Serial.print(angle_y_accel);
      Serial.print("\t");
      Serial.print(angle_z_accel);
      Serial.print("\t");
      Serial.print(angle_x);
      Serial.print("\t");
      Serial.print(angle_y);
      Serial.print("\t");
      Serial.print(angle_z);
      Serial.print("\t");
      Serial.println(((float)(millis() - t) / (float)dt) * 100);
      while ((millis() - t) < dt) { // Making sure the cycle time is equal to dt
        // Do nothing
    تست کردم....
    این خطا را داد
    Arduino: 1.6.6 Hourly Build 2015/10/22 05:42 (Windows 7), Board: "Arduino/Genuino Uno"
    F:\My circuits\gyro\omega-gyroXXX\omega-gyroXXX.ino:13:24: fatal error: gyro_accel.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling.
  2. #62
    نقل قول نوشته اصلی توسط farshad123456 نمایش پست ها
    تست کردم....
    این خطا را داد
    exit status 1
    Error compiling.
    ممممممممم
    داره از کتابخونه ایراد میگیره
    کتابخونه رو اضافه کن مشکلت حل میشه
  3. #63
    Oct 2015
    ممممممممم
    مرسی
    لطفا فایل کتابخونه را برام بزارین.... کتابخونه قبلی جواب نمیده
  4. #64
    مرسی
    هدر کد اسم کتابخونه هست
    جستجو کنید دوست عزیز
  5. #65
    Oct 2015
    مرسی...
    کتابخونه را استفاده کردم...فقط بازم خطا داد!
    In file included from F:\My circuits\!!!!!!!!!!!! ط¢ط±ط¯غŒظ†ظˆ\ط³ظپط§ط±ط´ط§ طھ ط®ط±غŒط¯\gy-521 mpu6050 example code\MPU6050_Arduino-master\Ver_0_1b\Gyro_header\farshad268\farshad268. ino:13:0:
    sketch\gyro_accel.h:1:19: warning: extra tokens at end of #ifndef directive [enabled by default]
    #ifndef gyro_accel.h
    sketch\gyro_accel.h:2:21: warning: ISO C99 requires whitespace after the macro name [enabled by default]
    #define gyro_accel.h
    farshad268:22: error: expected initializer before '_x_accel'
    F:\My circuits\!!!!!!!!!!!! ط¢ط±ط¯غŒظ†ظˆ\ط³ظپط§ط±ط´ط§ طھ ط®ط±غŒط¯\gy-521 mpu6050 example code\MPU6050_Arduino-master\Ver_0_1b\Gyro_header\farshad268\farshad268. ino: In function 'void loop()':
    farshad268:59: error: 'angle_x' was not declared in this scope
    farshad268:60: error: 'angle_y' was not declared in this scope
    farshad268:66: error: 'angle_z' was not declared in this scope
    farshad268:69: error: 'angle_z_accel' was not declared in this scope
    farshad268:69: error: 'accel_x_scal' was not declared in this scope
    farshad268:70: error: 'angle_y_accel' was not declared in this scope
    farshad268:70: error: 'accel_z_scal' was not declared in this scope
    farshad268:71: error: 'angle_x_accel' was not declared in this scope
    exit status 1
  6. #66
    مرسی...
    exit status 1
    وا
    این چیه!
    مممممممم
    فایل کتابخونتوبزار ببینم تو سیستم منم همینه!
  7. #67
    Oct 2015
    وا
    این چیه!
    مممممممم
    راستش منم چیز زیادی از آردوینو نمیدونم...این تخصص شماست
    اینم کتابخونه...
    extern int accel_x_OC, accel_y_OC, accel_z_OC, gyro_x_OC ,gyro_y_OC, gyro_z_OC; // offset variables
    extern float temp_scalled,accel_x_scalled,accel_y_scalled,accel _z_scalled,gyro_x_scalled,gyro_y_scalled,gyro_z_sc alled; //Scalled Data varaibles
    void MPU6050_ReadData();
    void MPU6050_ResetWake();
    void MPU6050_SetDLPF(int BW);
    void MPU6050_SetGains(int gyro,int accel);
    void MPU6050_OffsetCal();
    #endif
    Last edit date = 2014-06-22
  8. #68
    اینم کتابخونه...
    #endif
    فایل زیپ کتابخونه
  9. #69
    Oct 2015
    فایل زیپ کتابخونه
    من این فایل را گرفتم https://codeload.github.com/helscrea...ino/zip/master
    از این پوشه استفاده کردم
    Ver_0_1b/Gyro_header
  10. #70
    باید فرمتش رو شبیه به فرمت بقیه کتابخونه ها بکنی
    الان متفاوته
    به بقیه کتابخونه هات نگاه کن چه شکلین
    همشون به فولدر دارن به نام examples
    به نظر من اگه موفق نشدی کتابخونه و کدت رو عوض کن
