سلام خدمت دوستان
یه کد خیلی ساده قرار میدم اینجا تا همه به راحتی متوجه کارکرد این ماژول بشن. چون خودم اولش که خواستم روش کد نویسیش رو متوجه بشم ، چیزی نفهمیدم ولی با این کد هم خودتون میتونید طیف های مختلف رنگ رو بسازید و هم خیلی ساده هست.
فقط کافیه مقادیر رو توی تابع (آبی.سبز.قرمز) pixels.setPixelColor جا گذاری کنید.
کد:// NeoPixel Ring simple sketch (c) 2013 Shae Erisson // released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library #include <Adafruit_NeoPixel.h> #ifdef __AVR__ #include <avr/power.h> #endif // Which pin on the Arduino is connected to the NeoPixels? // On a Trinket or Gemma we suggest changing this to 1 #define PIN 6 // How many NeoPixels are attached to the Arduino? #define NUMPIXELS 16 // When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals. // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest // example for more information on possible values. Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800); int delayval = 500; // delay for half a second void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code pixels.begin(); // This initializes the NeoPixel library. } void loop() { // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one. for(int i=0;i<NUMPIXELS;i++){ // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255 pixels.setPixelColor(i, pixels.Color(255,0,0)); // Moderately bright green color. pixels.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } }
16 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
