نمایش نتایج: از 1 به 10 از 49
Like Tree8 لایک
موضوع: کمک در باره پروزه به یک مبتدی
    Oct 2016
    این کل چیزی که نوشتم دیبایسینگ هم توش استفاده کردم ولی خوب خیلی کند هستش .
      #include <EEPROM.h>
      #include <Bounce2.h>
      #include <Wire.h>
      #include "RTClib.h"
      #include <SoftwareSerial.h>;
      #include "JDateLib.h"
      #include <SHT1x.h>
      #define setBUTTON 13
      #define upBUTTON 11
      #define downBUTTON 12
      #define dataPin  8
      #define clockPin 9
      Bounce set;
      Bounce up;
      Bounce down;
      LiquidCrystal_I2C lcd(0x3F,16,2);
      SoftwareSerial Bolo(2,3);
      RTC_DS1307 RTC;
      SHT1x sht1x(dataPin, clockPin);
      unsigned long prevMillis = 0;
      unsigned long currentmillis = millis();
      static byte prevsetButton;
      static byte  prevSetMode;
      byte setMode;
      int tempmax = 20;
      int tempmin = 20;
      int Humiditymin = 20;
      int Humiditymax = 20;
      int state;
      String jdate;
      int JY,JM,JD;
      const int rala1  = 4;
      const int rala2  = 5;
      const int rala3  = 6;
      const int rala4  = 7;
      byte termometru[8] ={B00100,B01010,B01010,B01110,B01110,B11111,B11111,B01110};
      byte picatura[8] = {B00100,B00100,B01010,B01010,B10001,B10001,B10001,B01110,};
      byte m[8] = {B00000,B00000,B10001,B01010,B00100,B10001,B01010,B00100,};
      byte x[8] = {B00000,B00000,B00100,B01010,B10001,B00100,B01010,B10001,};
      byte l[8] = {B00001,B00011,B00111,B01111,B01111,B00111,B00011,B00001,};
      byte k[8] = {B10000,B11000,B11100,B11110,B11110,B11100,B11000,B10000,};
    void setup(){
      lcd.begin(16,2);
      lcd.clear();
      lcd.init();
      lcd.backlight();
      lcd.createChar(1,termometru);
      lcd.createChar(2,picatura);
      lcd.createChar(3,x);
      lcd.createChar(4,m);
      lcd.createChar(5,l);
      lcd.createChar(6,k);
      Bolo.begin(9600);
      Wire.begin();
      pinMode(rala1, OUTPUT);
      pinMode(rala2, OUTPUT);
      pinMode(rala3, OUTPUT);
      pinMode(rala4, OUTPUT);
      pinMode(setBUTTON,INPUT_PULLUP);
      pinMode(upBUTTON,INPUT_PULLUP);
      pinMode(downBUTTON,INPUT_PULLUP);
        set.attach (setBUTTON);
        set.interval(30);
        up.attach (upBUTTON);
        up.interval(30);
        down.attach (downBUTTON);
        down.interval(30);;
      digitalWrite(rala1, HIGH);
      digitalWrite(rala2, HIGH);
      digitalWrite(rala3, HIGH);
      digitalWrite(rala4, HIGH);
      tempmax = EEPROM.read(0);
      tempmin = EEPROM.read(1);
      Humiditymin = EEPROM.read(2);
      Humiditymax = EEPROM.read(3);
    void loop(){
      set.update();
      up.update();
      down.update();
    if ( setMode != 0) {
        if (currentmillis - prevMillis >= 10000UL) {
          setMode = 0;
          prevMillis = currentmillis;
    prevsetButton = setBUTTON;
      if (setMode >= 5) {
        setMode = 0;
      if (setMode != prevSetMode) {
        lcd.clear();
        prevSetMode = setMode;
     if (set.fell()) {  setMode++;  }
       DateTime now=RTC.now();
       show_time_and_date(now);    }
       void show_time_and_date(DateTime datetime){
       float h = sht1x.readHumidity();
       float t = sht1x.readTemperatureC();
      switch (setMode) {
          case 0://normal
      lcd.setCursor(0,0);
      if(datetime.hour()<10)lcd.print("0");
      lcd.print(datetime.hour(),DEC);
      lcd.print(":");
      if(datetime.minute()<10)lcd.print("0");
      lcd.print(datetime.minute(),DEC);
      lcd.setCursor(8, 0);
     Date now(datetime.year(),datetime. month(), datetime.day());
      JY = now.JYear();
      JM = now.JMonth();
      JD = now.JDay();
      lcd.print((JY)-1300);
      lcd.print("/");
      if(JD<10)lcd.print("0");
      lcd.print(JD,DEC);
      lcd.print("/");
      if(JM<10)lcd.print("0");
      lcd.print(JM,DEC);
      lcd.setCursor(1, 1);
      lcd.write(1);
      lcd.setCursor(3, 1);
      lcd.print(t,1);
      lcd.setCursor(5, 1);
      lcd.print((char)223);
      lcd.print("C");
      lcd.setCursor(9, 1);
      lcd.write(2);
      lcd.setCursor(11, 1);
      lcd.print(h, 1);
      lcd.println("%");
          break;  }
    switch (setMode) {
          case 1:
       if (up.fell())    {  tempmin++;  }
       if (down.fell())  {  tempmin--;  }
      lcd.print("    Set temp:");
      lcd.write(4);
      lcd.setCursor(2, 1);
      lcd.print(tempmin);
      lcd.setCursor(4, 1);
      lcd.write(5);
      lcd.setCursor(12, 1);
      lcd.write(3);
      lcd.setCursor(13, 1);
      lcd.print(tempmax);
      EEPROM.write(1, tempmin);
          break;  }
    switch (setMode) {
          case 2:
      if (up.fell())    {  tempmax++;  }
      if (down.fell())  {  tempmax--;  }
      lcd.write(4);
      lcd.print(tempmin);
      lcd.write(6);
      lcd.write(3);
      lcd.print(tempmax);
      EEPROM.write(0, tempmax);
      break;     }
    switch (setMode) {
          case 3:
      if (up.fell())    {  Humiditymin++;  }
      if (down.fell())  {  Humiditymin--;  }
      lcd.print("  Set Humidity:");
      lcd.write(4);
      lcd.print(Humiditymin);
      lcd.write(5);
      lcd.write(3);
      lcd.print(Humiditymax);
      EEPROM.write(2, Humiditymin);
      break;    }
    switch (setMode) {
          case 4:
      if (digitalRead(upBUTTON) == LOW)   {  Humiditymax++;  }
      if (digitalRead(downBUTTON) == LOW) {  Humiditymax--;  }
      lcd.write(4);
      lcd.write(6);
      lcd.write(3);
      EEPROM.write(3, Humiditymax);
      break;      }
    if(Bolo.available())  {state = Bolo.read();}
    if (state == '1') {
         digitalWrite(rala1, LOW);
         digitalWrite(rala2, LOW);         }
    else if (state == '0') {
         digitalWrite(rala2, HIGH);        }
    else if (state == 'A') {digitalWrite(rala1,LOW); }
    else if (state == 'a') {digitalWrite(rala1,HIGH);}
    else if (state == 'B') {digitalWrite(rala2,LOW); }
    else if (state == 'b') {digitalWrite(rala2,HIGH);}
    if( t <= tempmin )              {digitalWrite(rala4,LOW);  Bolo.print("       T on");  }
    else if( t >= tempmax )         {digitalWrite(rala4,HIGH); Bolo.print("       T off"); }
    if( h <= Humiditymin )          {digitalWrite(rala3,LOW);  Bolo.print("          H on");  }
    else if( h >= Humiditymax )     {digitalWrite(rala3,HIGH); Bolo.print("          H off"); }
      Bolo.print(t,1);
      Bolo.print("C");
      Bolo.print("      ");
      Bolo.print(h,1 );
      Bolo.println("%");
      Bolo.print("         tmin : ");
      Bolo.print(tempmin );
      Bolo.print("         tmax : ");
      Bolo.print(tempmax );
      Bolo.print("         Hmin : ");
      Bolo.print(Humiditymin );
      Bolo.print("         Hmax : ");
      Bolo.print(Humiditymax );
    [/QUOTE]
      #include <EEPROM.h>
      #include <Wire.h>
      #include "RTClib.h"
      #include <SHT1x.h>
      #define upBUTTON 11
      #define dataPin  8
      #define clockPin 9
      Bounce set;
      Bounce up;
      Bounce down;
      RTC_DS1307 RTC;
      byte setMode;
      int tempmax = 20;
      int tempmin = 20;
      int state;
      String jdate;
      int JY,JM,JD;
    void setup(){
      lcd.begin(16,2);
      lcd.clear();
      lcd.init();
      lcd.backlight();
      Bolo.begin(9600);
      Wire.begin();
        set.interval(30);
        up.interval(30);
        down.interval(30);;
    void loop(){
      set.update();
      up.update();
      down.update();
          setMode = 0;
      if (setMode >= 5) {
        setMode = 0;
        lcd.clear();
      switch (setMode) {
          case 0://normal
      lcd.setCursor(0,0);
      lcd.print(":");
      JY = now.JYear();
      JM = now.JMonth();
      JD = now.JDay();
      lcd.print("/");
      lcd.print(JD,DEC);
      lcd.print("/");
      lcd.print(JM,DEC);
      lcd.write(1);
      lcd.print(t,1);
      lcd.print("C");
      lcd.write(2);
      lcd.print(h, 1);
      lcd.println("%");
          break;  }
    switch (setMode) {
          case 1:
      lcd.write(4);
      lcd.print(tempmin);
      lcd.write(5);
      lcd.write(3);
      lcd.print(tempmax);
          break;  }
    switch (setMode) {
          case 2:
      lcd.write(4);
      lcd.print(tempmin);
      lcd.write(6);
      lcd.write(3);
      lcd.print(tempmax);
      break;     }
    switch (setMode) {
          case 3:
      lcd.write(4);
      lcd.write(5);
      lcd.write(3);
      break;    }
    switch (setMode) {
          case 4:
      lcd.write(4);
      lcd.write(6);
      lcd.write(3);
      break;      }
    if (state == '1') {
      Bolo.print(t,1);
      Bolo.print("C");
      Bolo.print("      ");
      Bolo.print(h,1 );
      Bolo.println("%");
    [/QUOTE]
    کدی که من زدمو برات فرستادم رو ببین
    بدون استفاده از دیبانس
    فقط پینهای سوئیچم رو inputpullup کردم و استفاده کردم .
    سرعتش واکنش سوئیچ هاش مناسبه
    میتونه با delay (200) ای که گذاشتم بازی کنی و سرعت مطلوبت رو تنظیم کنی
