/* Author = helscream (Omer Ikram ul Haq)
  Last edit date = 2014-10-08
  Website: Arduino with MPU6050 and angle calculation – HobbyLogs
  Ver: 0.1 beta --- Start
  Ver: 0.2 beta --- Bug fixed for calculating "angle_y_accel" and "angle_x_accel" in "Gyro_header.ino" file
#include <Wire.h>
#include "gyro_accel.h"
// Defining constants
#define dt 20 // time difference in milli seconds
#define rad2degree 57.3 // Radian to degree conversion
#define Filter_gain 0.95 // e.g. angle = angle_gyro*Filter_gain + angle_accel*(1-Filter_gain)
// Global Variables
unsigned long t = 0; // Time Variables
float angle_x_gyro = 0, angle_y_gyro = 0, angle_z_gyro = 0, angle _x_accel = 0, angle_y_accel = 0, angle_z_accel = 0, angle_x = 0, angle_y = 0, angle_z = 0;
// Main Code
  Serial.begin(115200);
  Wire.begin();
  MPU6050_ResetWake();
  MPU6050_SetGains(0, 1); // Setting the lows scale
  MPU6050_SetDLPF(0); // Setting the DLPF to inf Bandwidth for calibration
  MPU6050_OffsetCal();
  MPU6050_SetDLPF(6); // Setting the DLPF to lowest Bandwidth
  Serial.print("gyro_x_scalled");
  Serial.print("\tgyro_y_scalled");
  Serial.print("\tgyro_z_scalled");
  Serial.print("\taccel_x_scalled");
  Serial.print("\taccel_y_scalled");
  Serial.print("\taccel_z_scalled");
  Serial.print("\tangle_x_gyro");
  Serial.print("\tangle_y_gyro");
  Serial.print("\tangle_z_gyro");
  Serial.print("\tangle_x_accel");
  Serial.print("\tangle_y_accel");
  Serial.print("\tangle_z_accel");
  Serial.print("\tangle_x");
  Serial.print("\tangle_y");
  Serial.print("\tangle_z");
  Serial.println("\tLoad");
  t = millis();
  int relaypin = 3;
  t = millis();
  MPU6050_ReadData();
  angle_x_gyro = (gyro_x_scalled * ((float)dt / 1000) + angle_x);
  angle_y_gyro = (gyro_y_scalled * ((float)dt / 1000) + angle_y);
  if (angle_y_gyro < 90) digitalWrite (relaypin, LOW);
  else digitalWrite (relaypin, HIGH);
  angle_z_gyro = (gyro_z_scalled * ((float)dt / 1000) + angle_z);
  angle_z_accel = atan(accel_z_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_x_scal led * accel_x_scalled))) * (float)rad2degree;
  angle_y_accel = -atan(accel_y_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree;
  angle_x_accel = atan(accel_x_scalled / (sqrt(accel_x_scalled * accel_x_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree;
  angle_x = Filter_gain * angle_x_gyro + (1 - Filter_gain) * angle_x_accel;
  angle_y = Filter_gain * angle_y_gyro + (1 - Filter_gain) * angle_y_accel;
  angle_z = Filter_gain * angle_z_gyro + (1 - Filter_gain) * angle_z_accel;
  Serial.print(gyro_x_scalled);
  Serial.print("\t");
  Serial.print(gyro_y_scalled);
  Serial.print("\t");
  Serial.print(gyro_z_scalled);
  Serial.print("\t");
  Serial.print(accel_x_scalled);
  Serial.print("\t");
  Serial.print(accel_y_scalled);
  Serial.print("\t");
  Serial.print(accel_z_scalled);
  Serial.print("\t");
  Serial.print(angle_x_gyro);
  Serial.print("\t");
  Serial.print(angle_y_gyro);
  Serial.print("\t");
  Serial.print(angle_z_gyro);
  Serial.print("\t");
  Serial.print(angle_x_accel);
  Serial.print("\t");
  Serial.print(angle_y_accel);
  Serial.print("\t");
  Serial.print(angle_z_accel);
  Serial.print("\t");
  Serial.print(angle_x);
  Serial.print("\t");
  Serial.print(angle_y);
  Serial.print("\t");
  Serial.print(angle_z);
  Serial.print("\t");
  Serial.println(((float)(millis() - t) / (float)dt) * 100);
  while ((millis() - t) < dt) { // Making sure the cycle time is equal to dt
    // Do nothing
