تست کردم....اینو تست کن :
کد:/* Author = helscream (Omer Ikram ul Haq) Last edit date = 2014-10-08 Website: Arduino with MPU6050 and angle calculation – HobbyLogs Location: Pakistan Ver: 0.1 beta --- Start Ver: 0.2 beta --- Bug fixed for calculating "angle_y_accel" and "angle_x_accel" in "Gyro_header.ino" file */ #include <Wire.h> #include "gyro_accel.h" // Defining constants #define dt 20 // time difference in milli seconds #define rad2degree 57.3 // Radian to degree conversion #define Filter_gain 0.95 // e.g. angle = angle_gyro*Filter_gain + angle_accel*(1-Filter_gain) // ************************************************** ******************* // Global Variables // ************************************************** ******************* unsigned long t = 0; // Time Variables float angle_x_gyro = 0, angle_y_gyro = 0, angle_z_gyro = 0, angle _x_accel = 0, angle_y_accel = 0, angle_z_accel = 0, angle_x = 0, angle_y = 0, angle_z = 0; // ************************************************** ******************* // Main Code void setup() { Serial.begin(115200); Wire.begin(); MPU6050_ResetWake(); MPU6050_SetGains(0, 1); // Setting the lows scale MPU6050_SetDLPF(0); // Setting the DLPF to inf Bandwidth for calibration MPU6050_OffsetCal(); MPU6050_SetDLPF(6); // Setting the DLPF to lowest Bandwidth Serial.print("gyro_x_scalled"); Serial.print("\tgyro_y_scalled"); Serial.print("\tgyro_z_scalled"); Serial.print("\taccel_x_scalled"); Serial.print("\taccel_y_scalled"); Serial.print("\taccel_z_scalled"); Serial.print("\tangle_x_gyro"); Serial.print("\tangle_y_gyro"); Serial.print("\tangle_z_gyro"); Serial.print("\tangle_x_accel"); Serial.print("\tangle_y_accel"); Serial.print("\tangle_z_accel"); Serial.print("\tangle_x"); Serial.print("\tangle_y"); Serial.print("\tangle_z"); Serial.println("\tLoad"); t = millis(); } void loop() { int relaypin = 3; t = millis(); MPU6050_ReadData(); angle_x_gyro = (gyro_x_scalled * ((float)dt / 1000) + angle_x); angle_y_gyro = (gyro_y_scalled * ((float)dt / 1000) + angle_y); if (angle_y_gyro < 90) digitalWrite (relaypin, LOW); else digitalWrite (relaypin, HIGH); angle_z_gyro = (gyro_z_scalled * ((float)dt / 1000) + angle_z); angle_z_accel = atan(accel_z_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_x_scal led * accel_x_scalled))) * (float)rad2degree; angle_y_accel = -atan(accel_y_scalled / (sqrt(accel_y_scalled * accel_y_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree; angle_x_accel = atan(accel_x_scalled / (sqrt(accel_x_scalled * accel_x_scalled + accel_z_scal led * accel_z_scalled))) * (float)rad2degree; angle_x = Filter_gain * angle_x_gyro + (1 - Filter_gain) * angle_x_accel; angle_y = Filter_gain * angle_y_gyro + (1 - Filter_gain) * angle_y_accel; angle_z = Filter_gain * angle_z_gyro + (1 - Filter_gain) * angle_z_accel; Serial.print(gyro_x_scalled); Serial.print("\t"); Serial.print(gyro_y_scalled); Serial.print("\t"); Serial.print(gyro_z_scalled); Serial.print("\t"); Serial.print(accel_x_scalled); Serial.print("\t"); Serial.print(accel_y_scalled); Serial.print("\t"); Serial.print(accel_z_scalled); Serial.print("\t"); Serial.print(angle_x_gyro); Serial.print("\t"); Serial.print(angle_y_gyro); Serial.print("\t"); Serial.print(angle_z_gyro); Serial.print("\t"); Serial.print(angle_x_accel); Serial.print("\t"); Serial.print(angle_y_accel); Serial.print("\t"); Serial.print(angle_z_accel); Serial.print("\t"); Serial.print(angle_x); Serial.print("\t"); Serial.print(angle_y); Serial.print("\t"); Serial.print(angle_z); Serial.print("\t"); Serial.println(((float)(millis() - t) / (float)dt) * 100); while ((millis() - t) < dt) { // Making sure the cycle time is equal to dt // Do nothing } }
این خطا را داد
Arduino: 1.6.6 Hourly Build 2015/10/22 05:42 (Windows 7), Board: "Arduino/Genuino Uno"
F:\My circuits\gyro\omega-gyroXXX\omega-gyroXXX.ino:13:24: fatal error: gyro_accel.h: No such file or directory
compilation terminated.
exit status 1
Error compiling.
 17   لایک
17   لایک    LinkBack URL
 LinkBack URL About LinkBacks
 About LinkBacks
			 نوشته اصلی توسط magmagmary
						 پاسخ با نقل قول
  پاسخ با نقل قول
 ...این تخصص شماست
...این تخصص شماست
