 2   لایک
2   لایک
				Post By amin_mh 2
				Post By amin_mh
 من تو قسمت اپلود کردن مشکل دارم
 Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega1280"
 In file included from sketch\Repetier.h:597:0,
 from C:\Users\amir\Desktop\Repetier-Firmware-master\src\ArduinoAVR\Repetier\Repetier.ino:184:
 sketch\HAL.h:80:0: warning: "SERIAL_RX_BUFFER_SIZE" redefined [enabled by default]
 #define SERIAL_RX_BUFFER_SIZE 128
 In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:224:0,
 from sketch\Repetier.ino.cpp:1:
 C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:53:0: note: this is the location of the previous definition
 #define SERIAL_RX_BUFFER_SIZE 64
 Sketch uses 96,250 bytes (75%) of program storage space. Maximum is 126,976 bytes.
 Global variables use 3,386 bytes (41%) of dynamic memory, leaving 4,806 bytes for local variables. Maximum is 8,192 bytes.
 avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf4
 avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf4
 Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
 برنامه مارلین هم لینک شما هم از سایت برداشتم نشد
							با عرض سلام خدمت شما دوست عزیز
 این فرم ور که شما روی بردتون آپلود کردیدrepetier هست و برای من marlin که کاملا باهم متفاوت هست
 اگر در مرحله راه اندازی اولیه هستید توصیه میکنم از مارلین استفاده کنید
 و قبل از بارگذاری این فرم ور ابتدا مطمئن بشید که درایور بردتون رو درست انتخاب کردید (باتوجه به چیپ AVR برد) و به درستی روی سیستمی که قراره آپلود رو باهاش انجام بدید نصب شده باشه
 بعد از اون هم قبل از آپلود یکبار کامپایل کنید اگر به در لایبراری های آردویینو جایی نیاز به فایل خاصی هست (باتوجه به آپشن هایی که فعال میکنید گاهی نیاز است فایل خاص آن را در لایبراری قرار دهید) اون رو در پوشه مربوطه کپی کنید
							سلام دوست عزیز شما میتونید من را راه تمایی کنید
 من برای پرینتر سه بعدی خود از کنترلر mksgen L V1.0 و از ال سی دی REPRAP DISCOUNT 12864 استفاده کردم. ال سی دی را روی برد نصب کرذم وقتی برد را روشن میکنم ال سی دی روشن نمیشه.
 برنامه ی marlin 1.8.5 را نیز روی برد آپلود کردم اما باز ال سی دی روشن نمیشه. در این حالت برد کار میکنه حتی وقتی دستی G-code میدم موتور ها حرکت میکنند اما نمایشگر روشن نمیشه و تنها اتفاقی که می افته اینه که با چرخاندن پتاسیومتر چراغ آبی رنگ روی برد چشمک میزنه لطفا من را راهنمایی کنید. ممنون
