کد مقایسه آیدی کارت :
کد:#include <SPI.h> #include <MFRC522.h> MFRC522 mfrc522(10, 9); byte Cardid[4] = {75, 79, 63, 76}; byte readCard[4]; boolean match = false; void setup() { Serial.begin(9600); SPI.begin(); mfrc522.PCD_Init(); } void loop() { if ( mfrc522.PICC_IsNewCardPresent()) { if ( mfrc522.PICC_ReadCardSerial()) { Serial.print("Card UID:"); for (byte i = 0; i < mfrc522.uid.size; i++) { readCard[i] = mfrc522.uid.uidByte[i]; Serial.print(readCard[i], HEX); } checkTwo(readCard, Cardid); Serial.println(); mfrc522.PICC_HaltA(); } } } void checkTwo ( byte a[], byte b[] ) { if ( a[0] != NULL ) // Make sure there is something in the array first match = true; // Assume they match at first for ( int k = 0; k < 4; k++ ) { // Loop 4 times if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail match = false; } if ( match ) { // Check to see if if match is still true Serial.print("Match"); } else { Serial.print("Not Match"); } }
3 لایک
LinkBack URL
About LinkBacks
پاسخ با نقل قول
