نوشته اصلی توسط
feredy2011
مرسی یعنی برای کاری که من میخوام بکنم این کد درسته ؟
int a = digitalRead(output);
b= !a;
digitalWrite (output,b);
مهندس بی زحمت راجب اون یکی پست هم کمکم کنید. خالی کردن بافر و... ممنون
بله میتونید همین کد رو استفاده کنید.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://www.arduino.cc
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
// the loop function runs over and over again forever
int a = 0;
digitalWrite (13, a);
delay(1000); // wait for a second
int b = !a;
digitalWrite(13, b); // turn the LED off by making the voltage LOW
